PXI
Installing a PXI 1031
I can't seem to get the M & A Explorer to recognize my PXI slots.
The chassis shows up but slots 2,3 & 4 come in as unknown.
I've got a PCI-4472 Dynamic Signal Acquisition board installed in slot 2 and I'm using a laptop with XP installed.
First time I've tried to set up this chassis and I'm not sure where to go from here.
(3,896 Views)
Hi TMac,
Is the card showing up under Devices and Interfaces?  What about in device manager?
Sammy Z.
(3,876 Views)
Sammy Z
It does show up on the "Devices and Interfaces" as an empty chassis.
Under Device Manager I have a 02 Micro 0Z711EZ1 Memory Card Bus Controller under PCMCIA adapters.
This is the only PCMCIA device I have installed so I am assuming that is the PXI-1031.
I also show a "Other PCI Bridge Device" under PCI Bridge Device that does not have a driver installed
TMac
(3,870 Views)
TMac 5437
Can you please attach a screenshot of MAX as well as a screenshot of the Device manager when viewed by connection. View>> View by Connection
 Also Let's Ensure that NI-DAQmx is installed.  To verify check under the software tree of Measurement and Automation Explorer and verify that NI-DAQmx is present there.
You say that the Chassis is empty what cards do you have other than the DSA device?
Charley Dahan
Global Account Manager
(3,857 Views)
Can't seem to get a screen shot into this reply.
I tired dropping it into Word and attaching the file but when I preview it there are red "x's" where the pictures were.
Tried copying and paste from Word and it is garbled code.
How do can I get a screen shot into this window/reply.
(3,854 Views)
Hi TMac,
What is the extension of your image?
Are you using the tree looking icon or the add attachements from the bottom?
Sammy Z.
(3,816 Views)
