I have to provide increasing voltage (Linear/Logarithmic) into my test board. I created a program using producer/consumer loops in LabView and while the output is visible on the waveform chart that is in the loop but there is no output voltage on the wire terminal. I have PXI4130 and PXI4110 on my PXIe1085 chassis. Is there a need to bring the output indicator out from the loop or it should provide the voltage on the pxi card?
When I take the output voltage indicator out of the loop, I only get the final value. I need rising voltage to be input in my test board at certain time intervals.
Is there any other way to take the values after every iteration outside the loop and update the previous values.
PS: I am fairly new to Labview. I have attached the VI for that purpose.
