09-02-2010 02:55 AM
Dear all, I have a problem with a PXI 1042Q.
The PXI is driven by a 8336-MXI4 and there are also some other boards like 4472.
It is impossible to switch off the PXI, the only way is to disconnect the power supply.
I open the chassis, the anterior switch with led seems to be ok, but if I put it on the OFF position nothing changes.
Could be a problem of the main board or the power supply?Do you have any other suggestion?
Thank you.
Andrea
09-03-2010 10:15 AM
Hi Andrea,
can you switch off the PXI 1042Q without controller and MXI bridge connected?
Serena
10-08-2010 07:07 PM
Can you also confirm that there is nothing connected to the DB9 on the back of the chassis? Specifically pin 5.
Refer to http://www.ni.com/pdf/manuals/371088a.pdf on page 2-8.
Tyler C
