10-15-2020 11:26 AM
On PXIe (Linux RT), is it possible to enable/configure PTP (1588-2008) without a PXI-6683H timing and sync card? I could do this on Pharlap using "NI-TimeSync Time Reference for IEEE 1588-2008".
I'm using a PXIe-8840 quad-core with 20.5 Linux RT system image and LabVIEW 2020. It seems I'm limited to using the NI-Sync drivers which require an ni-sync resource.
Solved! Go to Solution.
10-15-2020 11:46 AM - edited 10-15-2020 11:51 AM
I'd recommend checking out one of the examples mentioned here:
You can use the NI-Sync API on Linux RT even without a timing card.
Errr.. actually that might just be on cRIOs.. sorry can't remember if it works on PXI.
10-15-2020 12:12 PM
The cDAQ/cRIO controllers show up as an ni-sync resource, however the PXI does not, unfortunately.
10-15-2020 01:48 PM
According to NI-Sync 20.1 documentation,
"Time-based synchronization is fully supported on Phar Lap PXI(e) controllers. Time-based synchronization is supported on NI Linux Real-Time PXIe controllers only if the system includes a PXI-6683 Series timing and synchronization module."
https://www.ni.com/pdf/manuals/375085r.html
