04-05-2021 01:33 PM
Hi all,
I'd like to use PXIe-5645 receiver to read I/Q data. If it's possible to read the phase of I/Q signal directly, that would be the best. Otherwise I would use I/Q calculate the phase(tan(phase) = Q/I).
For now I only have access to the basic RFSA soft front panel installed. Do I need any specific license to read I/Q?
Thank you!
Solved! Go to Solution.
04-05-2021 10:24 PM
I believe you have LabVIEW, in that case, you can use the example finder and use the examples related to I/Q to capture the I/Q data. Looks like you would need to compute the phase yourself (use the arctangent function on the IQ data and convert radians to deg)
04-06-2021 01:46 PM - edited 04-06-2021 01:50 PM
Thank you for the reply.
My LabVIEW trial license has just expired. Is there a way to read I/Q data without using LabVIEW, for example a SCPI command?
04-06-2021 03:51 PM
You can use the same examples in C#.NET or Python to collect the I/Q data.
Unfortunately, I don't think there is a way for you to gather the I/Q data without programming software and using the RFSA driver.
Side note - PXI instruments do not use SCPI but proprietary drivers or IVI drivers. SCPI commands are text-based commands primarily for GPIB/Serial instruments.
04-06-2021 05:23 PM
I see, thanks.
I think I still need LabVIEW anyway.
