08-31-2018 11:06 AM
I have some NI hardware that I want to set up but I am not sure how to proceed (the last person to set the equipment up has left the organization.) Would appreciate some general advice.
1. I have some PXI-1033 chassis with some PXI modules installed. How do I get the data to/from these modules? Here is what I think needs to happen, is this right? I have some 8631 cards (PCIe) that should be plugged into a desktop PC. There seems to be a proprietary M-M cable that would run from the PCIe card in the desktop to the PXI chassis. Then I would run LabView on the PC to talk to the PXI instruments.
2. I have some PXI-1042 and PXIe-1062Q chassis with PXI instruments installed. In this case there is an embedded controller such as PXI-8176 and no proprietary high bandwidth cable on the back of the chassis. In this case do I need to run LabView on the embedded controller and then get the data off the chassis using an ethernet cable (for instance)? Is it possible to run the chassis tethered to a desktop PC that is running LabView, so the instruments are talking directly to the LabVew on the desktop PC?
09-11-2018 12:22 AM
