Hi Pavlo,
NI-TClk provides a very simple way to synchronize scopes or even different kinds of devices. In a couple of examples I checked you only need to pass an array of the scope, etc. session references you want to synchronize to the niTClk Configure For Homogeneous Triggers VI, then the niTClk Synchronize VI, and finally start the process with the niTClk Initiate VI.
In the LabVIEW Example Finder you will find several example programs that will explain the usage of niTClk VIs, just search for the term TClk.
Daniel Fulop
Dániel Fülöp
Field Application Engineer (CLA, CTA)
