PXI
How to shut down the NI PXIe-1073 chassis?
Hi community,
I just started using NI PXIe-1073 chassis.I was wondering how to power off the chassis manually when required. There is a way to shut the chassis down when it gets stuck by keep pressing the front power button for 3 seconds. Is there any other way to power down the chassis? Thank you!
Ahmad
(4,510 Views)
Hi Ahmad,
Is there a problem occurring that is causing you to find alternative ways of powering the chassis down?
If not, you can shut the chassis down normally, via the front power button, anytime as long as the computer you have it connected to is already powered off. You want to then ensure that the PXIe-1073 is powered on again prior to powering on the PC (assuming you'll be using the chassis).
Tyler C.
Technical Support Engineering
(4,478 Views)
