PXI
How to diagnosis PXI-1010 and SCXI hardware
HI ni,
I experienced some problems in our application.
Our hardware configuration is:
PXI-1010 chasis: Device 2: PXI-6527,Device 4:PXI-6713
DEVICE 5: PXI-6602,DEVICE 8: PXI-6052E
SCXI chasis: MODULE 1: SCXI-1100,Module 2: SCXI-1126
It was working fine, but now it always comes up warning code 10685, it means clock is too high. This was happen after I used this chasis to test a faulty scxi-1102.
I've tried to bypass this warning and all scxi-1102 channel give a flat line reading, the voltage is about -1.4 volt. Obvious there are something wrong with the hardware.
So I need to know how to loacte which cards are faulty ?
regards,
Fwu
(3,139 Views)
Hey Fwu,
Please refer to this discussion post. Let us know in this thread if you have any questions after reading the old post.
Justin
(3,140 Views)
Hello justin,
I faced the same problem while using 6052E with SCXI modules in SCXI 1001 chassis. In fact I was getting NaN with this warning( 10685). Actually the link that you were referring to seems to be moved from there. Can you tell me the discussion topic, so that I can search for it.
Regards
Kallis
BR
(2,968 Views)
