HI ni,
I experienced some problems in our application.
Our hardware configuration is:
PXI-1010 chasis: Device 2: PXI-6527,Device 4:PXI-6713
DEVICE 5: PXI-6602,DEVICE 8: PXI-6052E
SCXI chasis: MODULE 1: SCXI-1100,Module 2: SCXI-1126
It was working fine, but now it always comes up warning code 10685, it means clock is too high. This was happen after I used this chasis to test a faulty scxi-1102.
I've tried to bypass this warning and all scxi-1102 channel give a flat line reading, the voltage is about -1.4 volt. Obvious there are something wrong with the hardware.
So I need to know how to loacte which cards are faulty ?
regards,
Fwu
