05-16-2019 02:52 AM
I am new to PXI, I have a general question:
I have a notebook with LabVIEW 2017 Professional and windows 10.
Then I have a PXI-1078 Chassis with PXIe-8820 Controller and a few PXI cards .
I turned on the PXI Chassis, connected with its own usb mouse, keyboard and Display port to a monitor.
I noticed that it boots into a normal Windows 7 32bit OS.
It has no LabVIEW development installed, but only NI runtimes (VISA, etc...).
The goal of this PXI is to test electronic boards with a bed of nails.
At the end the final system will be a ATE (Automatic Test Equipment) that will be shipped to a contractor that will use it to test thousands of electronic boards.
So my questions are:
Solved! Go to Solution.
05-24-2019 05:47 AM
the PXIe controller is a full-fledged computer. You can develop an application on your notebook, and then use the Application Builder (included in LabVIEW Professional, or available as an optional add-on in LabVIEW Base and Full) to build an executable to be deployed to the controller. This tutorial can serve as a starting point. You may need to activate a LabVIEW license on the PXI only if you wish to develop directly on the controller.
I hope I have been helpful, otherwise I remain available.
Alessia
05-24-2019 07:05 AM
Thanks for the reply
I can't develop an application on my notebook without access to PXI peripherals.
I've found the solution here: http://www.ni.com/tutorial/53757/en/
05-27-2019 02:18 AM
thank you for sharing your solution with the community.
Alessia
