PXI
How to control PXI-1031 with PXI-8336 with MatLab?
We are trying to control a  PXI-5922 mounted in a chassis PXI-1031 connected to a PC with a PXI-8336. We want to use MatLab. In the Test&Measurement Toolbox, you should be able to see the device. This is not the case. We also installed all the drivers (NI-VISA 14.0.1 and NI-SCOPE 14.1). The weird thing is that the device can  be seen in NI-MAX, but  as we told, we can not get a connection to Matlab. Also the command 'daq.getDevices' in Matlab does not return anything ('No data acquisition devices available.').
What can be the problem and how should we connect the device to Matlab?
Thanks in advance!
Jeroen
(4,753 Views)
The 5922 is not a DAQ device. As the driver you installed, it is a digitizer/scope that uses NI-Scope.
(4,541 Views)
