PXI
How do you actually use or access "Instrument Design Libraries for Reconfigurable Oscilloscopes"
I have a PXIe-5172 O-Scope card. I need to access the FPGA and see what advanced processing I can do with acquired data. My understanding is this card is NOT a flexRIO and so you can't do the typically FPGA programming on it but instead you have to use the "Instrument Design Libraries for Recondigurable Oscilloscopes" found here: LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Download - NI
I have searched all over and looked in the examples and palette's after installing this and can't find any information on where this library is located and how to use its code. Does anyone have more information on this?
Where is the code installed on my computer?
How do I write code that interfaces with the FPGA? Does it all end up being host code? Or do I have to somehow add an FPGA to my project and put the code under it.
Overall I'm pretty confused and unsure how to get started. This is not like other FlexRIO cards I've worked with.
Message 1 of 8
(3,901 Views)
Accepted by Be-lock-eh
1. File >> Create Project
2. Select Oscilloscopes - it says 5170 but these are for all of the 517x cards
3. Select any of the above three (above)
4. Select from the card and FPGA that you have
ALE Consultants
Message 2 of 8
(3,898 Views)
Use the Create Project window from the LabVIEW splash screen, you should see a section for the reconfigurable 517x scopes.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 3 of 8
(3,892 Views)
Thanks so much for this response. For some reason Oscilloscopes are not listed under the "Sample Projects":
But I do have "Instrument Design Libraries for Reconfigurable Oscilloscopes" installed:
Message 4 of 8
(3,869 Views)
@Terry_ALE
I don't have that option available. I am using 32 bit. Are you using 32 bit or 64 bit LabVIEW? I'm on 2022 Q3. What version of LabVIEW are you using?
Message 5 of 8
(3,823 Views)
@Be-lock-eh wrote:
@Terry_ALE
For this work, 2020 and 2021
ALE Consultants
Message 6 of 8
(3,800 Views)
From the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 21.5 Readme
https://tmesystems.net/
Message 7 of 8
(3,791 Views)
I don't know how I missed this that it only supports 2021.
It is now working in LabVIEW 2021 32 bit. Thanks everyone for the help you guys rock!
Message 8 of 8
(3,765 Views)
