11-06-2008 06:51 PM
I can't seem to figure out how to access the configuration channels for Analog Outputs (Channel 33 and 35) for the PXI-6704.
This piece of test equipment is out of tolerance, and needs to be calibrated.
I've followed the calibration procedure http://www.ni.com/pdf/manuals/374081b.pdf, but am getting hung up on the step 8 where it says to repeat steps 4-7 while changing _cal_ao_current_offset. I can't figure out how to open this channel as it is not listed as a physical channel for step 5.
I'm using Labview 7.1
Solved! Go to Solution.
11-10-2008 11:11 AM
