02-02-2015 02:16 AM
We are using a PXIe- 8135 Controller and a PXI-6528 DIO module in a PXIe-1082 chassis. We are sending DIO input and output commands using Powershell in Windows 7 on the controller. Due to tight requirements I need to know what is the max latency from when the Powershell command is issued to when the read input or write output command will take place in the DIO I/Os.
If this should be in a different Community Board Location please let me know.
Thanks for the help in advance,
Dan_F
02-03-2015 08:46 AM
Hello dan_f,
As the latency of Powershell and Windows are not tested, it is hard to determine the latency of your setup. The latency from the PXIe-8135 to the PXI-6528 should be in the realm of nanoseconds. The PXI-6528 does have a couple of latency numbers that can be found within the user manual on Page 24, and they are as follows:
Minimum pulse-width for change detection - 150 µs
Propagation delay - 65 µs, typical
You may be able to do some testing to ballpark the latency of the controller OS/software side of the input/output commands, but depending on how critical this latency is to your measurements, you may want to look into using a real-time OS instead.
