11-12-2011 05:14 PM
I'm completely new to using NI products, and I have to set up a Pine Biopotentiostat AFCBP1 in LabVIEW. The machine communicates with a PCI-MIO-16E-4 (PCI-6040E) card. I was wondering how you differentiate which of the 16 channels controls what on the machine? Thanks in advance.
Solved! Go to Solution.
11-14-2011 02:28 PM
Hi iibtc
In the Pine Ciopotentiostat AFCBP1 manual on page 4 there is a table that gives a brief summary of what each channel does on the 50 pin connector. The following pages describe a little further each of the channel types.
Assuming that you are using a 68 pin-to-50 pin cable adapter to connect your PCI to the device, the channels should correspond to that on your PCI-MIO-16E-4.
Let us know if it works for you!
Peter
