Do you simply wish to transfer data between your laptop and the PXI?, OR
Do you wish to run your application on the laptop and simultaneously see the front panel on the PXI?, OR
Do you wish to run the application on the PXI (after maybe having developed it on the laptop) while seeing the PXI 'transparently' from your laptop?
You may get a quick start from here:
If that does not help, pls describe your requirement and system config comprehensively.
Best,
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
