PXI
How can I control individual pins of VHDCI connector on PXIe-6548?
Accepted by topic author viaheaven
That's actually a cascaded error.  So basically, the configuration that Signal Express is looking for is for PFI4 to be wrapped back to PFI5.  There's a hidden error about the acquisition clock not being able to lock.  By connecting PFI4 to PFI5 you could avoid this.  This is a very simple example case.  If your system isn't clocked in this way, the play button won't work for you.
HOWEVER!
Now that we've created a HWS file with your drive and compare data, we can go back to LabVIEW (proper) and use the full capabilities to give you the ability to configure the PXIe-6548 to work with your system.
If you go to the Example Finder in LabVIEW in search for the keyword "compare", you should get some examples.  The one you want to start with is "Stimulus Response Load From HWS File.vi".
This file is documented in the code, but if your DUT is not providing a clock back to the PXIe-6548, you'll want to change the acquisition clock source to "Onboard Clock" from Strobe.
To make sure your acquisition session triggers, you might also set your Acquisition Start Trigger to PFI1 (which is connected to the Generation Data Active event).
Give that a try and let us know how it goes.
Message 31 of 35
(1,305 Views)
Thanks Keith.
As you said, I tried to run the "Stimulus Response Load From HWS File.vi". In the example, the data active event is exported to PFI 1. Is that necessary? Because the start trigger in acquisition session is configured as PFI 2. And then it is mentioned that an external connection between PFI1 and PFI2 is required.
When I run the example, I have specified dynamic channels as 0-19. Out of these 20 channels, channel 7-15 are configured for comparison. But when I see the output, i.e.. Acquired data, it shows 11 lines: plot 0, line 1 to line 10. What does this mean?
Is it necessary to tristate the channels 7-15 in the LabView VI although I have made them Bidirectional in the waveform itself. The example does not tristate the channels.
Message 32 of 35
(1,291 Views)
Hi Keith, is it possible to use the stimulus response express VI as a normal VI? I don't want to use it through signal express. If I convert it to a standard subVI, it shows an empty front panel. Please help.
Message 33 of 35
(1,247 Views)
My suggestion to change both start trigger and data active event to PFI1 is to avoid having to loop back PFI1 to PFI2.  If you don't mind doing the loopback, then you can do that as well.
I would actually expect that you would see 20 channels in the waveform.
No.  By having the waveform be compare only, no data will be driven on those channels, and so the tristate VI is unnecessary.
Is it possible to use the stimulus response express VI as a normal VI? I don't want to use it through signal express. If I convert it to a standard subVI, it shows an empty front panel.
No, it's not.  However, the ExpressVI is wrapped around normal LabVIEW calls (basically it's just some fancy programming that started from our examples).  It's designed to do very specific things quickly and with a nice UI.  For more advanced and custom designs, including your own UI, you'll need to start from the examples.
Have you tried disconnecting your DUT and running the examples as is to see if you can get them to work on your system?
Keith Shapiro
National Instruments R&D
Message 34 of 35
(1,241 Views)
Dear sir,
we are selected PXIe-8881 processor and selected other interphase are Analog input PXIe-4302 and extinction TB-4302C One set, Analog Output PXIe-6738 three cards, Digital input PXIe-6529 one card and Digital output PXIe-6513 three cards.
And still searching for ARINC825(2 Channels), ARINIC 429 (8 channels), RS422(18 Channels), TSN Ethernet (6 ports) and Ethernet (4 Ports).
For these boards interphaseing we need back plain, please suggest back plain part numbers.
If you want give any suggestions please suggest and encourage us please.
nsprateep@sirveen.com
Message 35 of 35
(146 Views)
