06-23-2010 11:50 AM
Unless you can post some screen shots or your code, I'm kind of at a loss. The PXIe-6548 does support stimulus/response mode. A device not found error generally indicates a that you haven't selected the correct device, not that a feature isn't present.
Can you share screen shots of what you're doing or your code?
06-23-2010 12:14 PM
I am attaching the screenshots of the DWE and Signal Express windows. The first image shows DWE where I save the waveform in proper format with signal mapping on channels. The second image shows how stimulus response shows an error.
06-23-2010 01:59 PM
Thanks - that's pretty helpful.
In SignalExpress, if you go to Help | About LabVIEW SignalExpress...
What versions of NI-HSDIO Express and Signal Express are you using?
Also, can you see your device in MAX?
I've attached a screen shot of my about panel.
06-23-2010 02:15 PM
Hi, I have MAX installed and I can see my device in MAX. I have attached my About window. It is pretty much same as your image.
06-23-2010 02:19 PM
What version is your NI-HSDIO?
06-23-2010 03:49 PM
where do i find what version is my niHSDIO?
06-23-2010 03:50 PM
If you look at my About window, you'll see NI-HSDIO Express toward the bottom. Yours should also be in the About box.
06-23-2010 03:54 PM
it says version 1.3.0.
06-23-2010 04:08 PM
NI-HSDIO 1.3 doesn't support the PXIe-6548...
Please upgrade to HSDIO 1.7.2: http://joule.ni.com/nidu/cds/view/p/id/1625/lang/en
06-23-2010 06:35 PM
Thanks very much Keith!
I upgraded it to 1.7.2 and tried to run the stimulus response. It shows the device now but gives another error. I am attaching the screenshot. Please tell me the possible reason for the error.
