We are facing the strange issue with the NIMAX and our dll application.
We are using NI PXI Cancard for communication.
We have developed an application in vc++.net 2003 to flash the ECU's .At test bench when we try to flash the ecu it is taking longer time(5 minutes) to flash when NIMAX is not running i.e not opened.
If we open NIMAX and flash the ecu it is taking shorter time(1 minute).
How NIMAX opening making ECU flash in less time.
Can you please clarify as soon as possible?
Thanks and Regards,
vinaya
