PXI
Help Needed to Confirm Memory Size of My PXI-5114 Using Serial Number
I’m reaching out for assistance in determining the onboard memory size of my PXI-5114 high-speed digitizer. I understand that the PXI-5114 offers several memory options (8 MB, 64 MB, or 256 MB per channel), and I’d like to confirm the exact configuration of my specific device.
Since I don’t have documentation specifying the memory, I was wondering if it’s possible for NI support or any community member to help me verify the memory size by using my device’s serial number. If there’s a straightforward way to find this information or if there are alternative suggestions, I would really appreciate the guidance.
Thank you in advance for any help!
Chen
(1,209 Views)
Alternative suggestion: Maybe this ancient answer could help?
(1,207 Views)
Accepted by topic author Chen-T
You can use the part number on the module. Here are the part numbers for the different 5114 form factors and their respective memory.
Part Numbers:
195681x-01L NI PCI-5114, 8MB/CH
195681x-02L NI PCI-5114, 64MB/CH
195681x-03L NI PCI-5114, 256MB/CH
192897x-01L NI PXI-5114, 8MB/CH
192897x-02L NI PXI-5114, 64MB/CH
192897x-03L NI PXI-5114, 256MB/CH
156860x-01L NI PXIe-5114, 16MB/CH
156860x-02L NI PXIe-5114, 128MB/CH
156860x-02L NI PXIe-5114, 512MB/CH
The "x" here is a placeholder for whatever hardware revision you have. On yours, it'll be a different letter, but it's the number after that dash that matters.
(1,175 Views)
Thank you so much for your help! Your answer was exactly what I needed, and it solved my problem. I really appreciate you taking the time to explain everything so clearly. Thanks again.
(1,155 Views)
Happy I could help and I'm glad to hear that this was the information you needed!
(1,141 Views)
