PXI
[HELP] NI MAX Error and Lockup...
I have a NI PXIe 1062Q and NI PXIe 8135.  Windows 7 Professional 64-bit installed.
I removed all the NI software using the control panel and then installed NI Developer Suite 2012. As part of the install the following was installed:
NI Developer Suite Core
FPGA Deployment Option (Excluding Xilinx Compilation Tools 10.1)
Automated Test Option
I2C & SPI
NI Serial + VISA
When I start NI MAX it errors with an exception. If I continue it then locks up. All the menus are greyed out! It was working (with the error), but now it locks up completely.
I have attached the dump and log file.
Also in the rack are:
PXI-6509 DIO Card
PXI-7953R + 5734R DAQ + FPGA
CB2-1-PIPE USB controller
PXI-2503 Switch
PXI-4070 DMM
PXI-8430/4 RS-232 Card
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(4,712 Views)
Hi Christopher,
Can you access MAX at all? You may be having a problem with the MAX database, a description of how to reset it can be found here:
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9?OpenDocument
If this doesn't solve your problem, please let me know.
Ingram
(4,674 Views)
Accepted by topic author ChristopherPovey
I worked it out in the end.
The PXI chassis came pre-installed with a few cards we had ordered. I think NI installed the drivers for these cards (probably later than 2012). I then removed all the NI software from the Control Panel and installed NI Developer Suite 2012. I think the drivers clashed. I did a full system restore from the image on the drive and re-installed NI Developer Suite 2012 and it was fine.
Christopher Povey
(4,651 Views)
