PXI
FlexRIO NI PXIe-7972R + NI 1483 cannot compile w/ Xilinx Vivado 2013.4
I'm using LabView 2014 and trying to use NI PXIe-7972R + NI 1483 adapter to capture image from camera-link pco.edge camera. After install the driver of the PXIe-7972R, I try to compile the example target with "10-Tap 8 Bit Camera.lvproj" project. The PXIe-7965(with Virtex-5 FPGA) can compile off-line successful. However, when I try to compile the PXIe-7976R and PXIe-7972R FPGA target (both have Kintex 7 FPGA) with Vivado 2013.4, it doesn't work as attachment figure. I'm pretty sure the Vivado 2013.4 can support the  PXIe-7976R and  PXIe-7972R target (http://www.ni.com/product-documentation/53056/zht/), and I already install this compiler.
It seems Kintex-7 FPGA compiler have some problem.
The attachment are my error figure and code from example, thanks.
Message 1 of 1
(1,775 Views)
