PXI
FPGA 64-bit compilation for PXI-7842R board
Does anyone know if FPGA 23.1.0 (2023) 64-bit or later versions will support compilation on the PXI-7842R board?
FPGA Target Support for the LabVIEW FPGA Module 64-bit - NI
Gave me hope it would on the PXIe variant, but then I spotted "(Except the PXIe 7841/2R)". My project opened in 2023 Q3 (64) with FPGA 23.1.0 is showing the warning that the FPGA module doesn't support the current target.
Has anyone experience of compiling on the 32-bit version then running from LabVIEW using the 64 bit toolkit as the KB suggests? Any caveats?
Mark
Certified LabVIEW Architect
(1,164 Views)
I was able to add PXI-7842 and PCIe-7842 to a LabVIEW 2023 32-bit but not 64-bit.  There are several targets that are not supported in 64-bit.
I could not see a PXIe-7842; does this even exist?  I think the article may be incorrect; I will send feedback.
ALE Consultants
(1,144 Views)
Hi Terry,
Thanks for taking the time to investigate. We’ve actually decided to use a different R series board which is supported under 64-bit, so easy fix.
Cheers,
Mark
(1,117 Views)
