04-04-2013 10:47 AM
HI,
I have PXI 8106 with real time software. I'm trying to iinstall labview runtime engine 11.0 and veristand run time engine 11.0, But i'm getting after installation from MAX. After installation of the software it gives NI variable engine: ERROR: Unable to load the MXS configuaration plugin.
Please do tell me how remove this error?
04-05-2013 08:10 AM
Hi jay,
have you installed the real time operating system once again?
In my opinion it´s the best to solve those kind of problem.
Greetings
04-05-2013 08:24 AM
No i have not installed the real time OS. How to re-install the real time os?
04-08-2013 08:30 AM
Hi Jay!
First: Format your Real-Time PXI
http://digital.ni.com/public.nsf/allkb/54F470CCF153945C86257711004F4248?OpenDocument
Secondly: Install the required software and drivers
http://digital.ni.com/public.nsf/allkb/D170D1AF82303EA086256B4200780579?OpenDocument
or
http://www.ni.com/white-paper/12871/en
Much success!!!
04-08-2013 09:07 AM
Thanks a lot formating and reinstalling worked, but there's another problem now. I'm not able to see the NI veristand real time engine 11.0 running. But i have installed the software with Labview real time 11.0.
Please do help if any suggestions.
04-08-2013 10:23 AM
first install Veristand on your host, after that deploy the real-time engine to your target.
http://www.ni.com/white-paper/14126/en#toc1
04-08-2013 10:29 AM
HI,
I have done like that only. But it doesn't seeems to appear on the console.
04-09-2013 07:24 AM
please send me a Max-Report from your system?
Documenting Measurement & Automation Explorer (MAX) Configuration Information Through MAX Technical Report
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Make a screenshot of the Software which is available to install on your target. (see attachment)
04-10-2013 08:56 AM
could you solve the problem?
