04-09-2024 05:25 PM
Hello All,
I am new to LabVIEW and also to LabVIEW FPGAs.
I have this error shown in the attached image after compiling the VI on the FPGA (NI PXI 7841R).
How do I fix this?
Thank you.
04-09-2024 09:15 PM
As mentioned in the popup window, specify a resource for your FPGA target.
If you are unsure how to do that, attach your entire LabVIEW project and we can point out what needs to be done.
04-10-2024 11:40 AM
This is the project file to test the FPGA.
I have a numeric control going into a numeric indicator.
04-10-2024 06:25 PM
There is nothing attached.
04-10-2024 06:31 PM
So I tried attaching .lvproj file but I keep getting error that the file has been removed.
04-10-2024 06:47 PM
Attach .lvproj alone is not enough. You need to attach the entire project including .lvproj and VI.
Zip the entire project and you can attach it.
04-10-2024 08:21 PM
The '.lvproj' file has been compressed and attached now.
The 'lvproj' has the 'vi' in there now.
04-10-2024 09:01 PM
You didn't provide the VI.
What you provide:
What we need:
04-11-2024 06:47 PM
The VI has been attached now.
Thank you.
04-11-2024 07:13 PM
You did not specify a Resource Name for your FPGA target.
In LabVIEW project, right-click on your FPGA target and select Properties. Under the General tab, fill in the Resource name. You can get the resource name of your FPGA target in NI MAX.
