PXI
Error Running VI on FPGA
Hello All,
I am new to LabVIEW and also to LabVIEW FPGAs.
I have this error shown in the attached image after compiling the VI on the FPGA (NI PXI 7841R).
How do I fix this?
Thank you.
Message 1 of 11
(2,122 Views)
As mentioned in the popup window, specify a resource for your FPGA target.
If you are unsure how to do that, attach your entire LabVIEW project and we can point out what needs to be done.
https://tmesystems.net/
Message 2 of 11
(2,096 Views)
This is the project file to test the FPGA.
I have a numeric control going into a numeric indicator.
Message 3 of 11
(2,073 Views)
There is nothing attached.
Message 4 of 11
(2,064 Views)
So I tried attaching .lvproj file but I keep getting error that the file has been removed.
Message 5 of 11
(2,056 Views)
Attach .lvproj alone is not enough. You need to attach the entire project including .lvproj and VI.
Zip the entire project and you can attach it.
Message 6 of 11
(2,051 Views)
The '.lvproj' file has been compressed and attached now.
The 'lvproj' has the 'vi' in there now.
Message 7 of 11
(2,037 Views)
You didn't provide the VI.
What you provide:
What we need:
Message 8 of 11
(2,032 Views)
The VI has been attached now.
Thank you.
Message 9 of 11
(2,005 Views)
You did not specify a Resource Name for your FPGA target.
In LabVIEW project, right-click on your FPGA target and select Properties. Under the General tab, fill in the Resource name. You can get the resource name of your FPGA target in NI MAX.
Message 10 of 11
(2,001 Views)
