PXI
Error -63150 occurred at niLvFpga_Open_PXIe-7820R.vi:6390001
Hello !!
I have a PXIe-1082 Chassis with two FPGA Card 7851R and 7820R. i have connected the  PXI system to a PC via MXI. When i try to load the FPGA bit file to 7820R i get the above error which is stated in the subject.  but i am load the FPGA model which was built for 7851R card successfully.
i have not connected any of the DIO lines. its a brand new card and i was just checking if the FPGA Code/Models can be successfully loaded. is it software error (related to any of the drivers) or HW issue.. i have the second setup with same chassis and same Card and i see the same issue in that Chassis also.. Any help to resolve this problem is highly appreciated.
i am using Labview 2020 32 bit version of the software.
regards
Kiran
Message 1 of 9
(2,613 Views)
Are you running a shipping example?  How are you loading a bitfile?
ALE Consultants
Message 2 of 9
(2,594 Views)
Hello Terry..
what do you mean by shipping example.. i am loading the bit file using the labview VI (Open FPGA VI ).
even i tried using veristand (FPGA Addon Custom device) and tried deploying. i get error in Veristand also.
Refer the attached images..
thanks
Message 3 of 9
(2,583 Views)
see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIKbCAO&l=en-US
Can you open an example project and VI for this hardware and try running it?
ALE Consultants
Message 4 of 9
(2,578 Views)
Thanks for sharing the link. i get the same error with the shipping example also.
refer attached image
Message 5 of 9
(2,569 Views)
the examples are tested and are supposed to work, they are best starting place and sanity check
your problem is likely hardware or drivers and not a LabVIEW/software issue
ALE Consultants
Message 6 of 9
(2,564 Views)
Thanks, Terry.
i have raised a service request with NI. will keep you updated with the solution i get from NI.
Message 7 of 9
(2,543 Views)
Same Error with sample form example, and I replaced another same module(PXIe-7821R), It fixed!
So, try another module if you have.
Message 8 of 9
(2,059 Views)
Hi.
Thanks for the reply.. i had another 7820R module and see the same error.
The Module seems to be good.. becuase it works when it is connected with different setup.
the problem seems to be with Host PC Bios /Drivers. Teh PXI chassis is connected to Host Machine/PC via MXI.
Message 9 of 9
(2,047 Views)
