PXI
Error -1073807360 occurred at niSync (test panel) when PXIe-6674T route DStarC signal in 3rd party chassis
Hi Sir,
I'm wondering if PXIe-6674T can work with 3rd Party chassis for routing DStarC signal?
Test panel pops error when routing DStarC with  3rd Party chassis  but 1085 chassis works well.
Error -1073807360 occurred at niSync Connect Trigger Terminals.vi
(2,148 Views)
May I know which version of the VISA and window you are using? Do you use LabVIEW? What is the model of the 3rd Party chassis? Have you install the 3rd Party driver?
(2,091 Views)
The chassis is ADLINK PXES-2590.
ADLINK PXI Platform Service software has been installed in the system.
It seems like NI MAX thinks that 6674T is not in "System Timing Slot".DeviceRoute.PNG
(1,799 Views)
