PXI
Eliminate noise in SMB 2147
Hi guys,
I have created a VI to acquire the AI reading of sensor using PXIe 7962r. The acquisition clock is at 10MB/s using SCTL. This module is connected with NI 5751 adapter. Then it is connected with NI SMB 2147 through SHC68-C68-D4. This setup is recommended by NI. To ensure the reading is valid, I have checked each channel at SMB 2147. However, the reading is different for each channel even though the source is from the similar sensor. Some reading can be categorized as noise.
Anyone have an idea why some channel produced a noise? And how to eliminate this noise?
Thank you.
Message 1 of 1
(4,001 Views)
