10-31-2014 07:40 PM
I am getting an error with my PXIe-4139 module. I have a PXIe-1075 Chassis configured with 2 NI PXI-4070 modules, 2 NI PXIe-4139 modules, and 3 NI PXI-4130 modules.
When I boot my computer, one PXIe-4139 module will turn on with Access light green and Active light green. The other PXIe-4139 module will turn -on the same way, but in a short time the access light will turn off and the Active light will turn red. I tried running the self-test in NI MAX, but I get this message.
The self test failed.
-235140
Internal Hardware Error occurred in Power_Supply hardware. Please contact National Instruments Support.
I tried changing its PXIe slot, but I had the same error. Should I send this card in for checkout?
Thanks a bunch!
11-03-2014
11:11 AM
- last edited on
12-10-2024
05:45 PM
by
Content Cleaner
You can submit a Service Request for RMA online if you have an SSP Contract. Select "Yes" for Troubleshooting if you want to speak with an Applications Engineer to troubleshoot before sending it in for repair/replacement and "No" if you just want to process the RMA without troubleshooting.
If you don't have SSP, you can call: (866) 337-8760 or go here:
https://www.ni.com/en/shop/services/hardware/repair-replacement-services.html
12-04-2014 11:14 AM
Hey,
I wanted to give an update on this. I uninstalled NI-DCPower (I think I had version 1.9 installed) and installed NI-DCPower version 14.1. Everything is working great.
06-08-2018 06:26 AM
it's been a looong time, but can you tell me how you did that, because i have the same problem but i can't find how to uninstalle the NI-DCPower
06-11-2018
03:58 PM
- last edited on
12-10-2024
05:46 PM
by
Content Cleaner
You migh follow the following document to unistall the program:
I also recommend to create a new post if needed, and reference this one.
06-11-2018 04:38 PM
Thank you so much. I already find a solution to my problem thanks
