PXI
Dual Boot RTOS + RTOS
I'm wondering if it is possible to configure a RT PXI system to dual boot with two (or more) RTOS.
In my case, this is needed because I need to switch very often from a LabView 2010SP1 system to a VeriStand 2011SP1 an back.
Googling around I've only found examples on doing it with Windows + RTOS.
Has anyone tryed to do it? Is It very tricky or It can be done by "normal" users of NI Instruments?
Tank's in advance for your help!!
Davide Galli
(4,328 Views)
unfortunately this feature is not supported. I suggest you to configure two different hard drives with your desired SW, switching them HW (mounting and unmounting them on the PXI)
Ragards,
Andrea R.
(4,315 Views)
