PXI
Download speed of NI PXIE-1085 (24GB/s) with 10 GbE Setup
I seem to be experiencing much slower speeds than anticipated on my NI PXle-1085 (24GB/s) Chassis with a 10 GbE network. I'm trying to download to a server and I was expecting to get download speeds of about 200 MB/s but instead I'm getting speeds of around 80 MB/s with an Intel driver installed instead of the standard which was even slower. Can anyone help fix this problem?
Thank you!
(2,636 Views)
Hey Ahusein,
The 10GbE network ports on the PXIe-1085 are capable of up to 1000Mb/s transfer rate. This would be equal to about 125MB/s maximum transfer rate for the line which is about only about 30% more than what you are seeing currently. This difference between the maximum and measured values could be caused by a number of different things including your network traffic, configuration, etc.
--Hunter
Hunter D.
(2,573 Views)
What are you using for a 10Gb NIC?  What controller are you using?
(2,566 Views)
