PXI
Direct Streaming of data from onboard memory to Host memory in PXI 5122
Hey All,
I have a small query about PXI 5122. In Data Sheet its written that " The PXI-5122 also can stream data continuously from onboard memory to host memory for longer acquisitions and streaming to disk. "
So do we have to write some code for streaming the data on hard disk or when drivers of this card is installed then some VI's will appear in control panel through which we can stream data on hard disk ??
I hope you all understood what my query is. Please let me know for further details
Thank you.
Sarang Dhananjay Jaiswal
Satyam Development Center, Banglore, INDIA
(2,190 Views)
hi sarang,
u have to write some code for streaming the data on hard disk,
for any applications using labview u need to do coding........
here is a vi which will do streaming of data on to hard disk
to know more about digitizers (C:\Program Files\National Instruments\LabVIEW 7.1\examples\instr\niScope\niScope EX Getting Started.vi)
or in labview goto
find examples \hardware input output \modular instruments\ NI-scope(high speed digitizers)
regards
ak
(2,181 Views)
