PXI
Difference between PXIe-4139 and PXIe-4138
I was looking at the PXIe-4139 when the 4138 caught my eye.  The only differences that I can tell is the 4139 can output 10A vs 3A for the 4138, and the 4139 has an order of magnitude better current sensitivity (100fA vs 1pA).
It looks like the sample rate and everything else is the same.  Are there any other differences that I'm missing?
(3,155 Views)
Accepted by topic author CurtisHx
Check out the document below, on page two you eill see a comparison table between both boards.
NI PXIe-4138, NI PXIe-4139
http://www.ni.com/datasheet/pdf/en/ds-522
Regards.
(3,112 Views)
The above document no longer exists. Replaced by: http://www.ni.com/pdf/product-flyers/pxi-source-measure-units.pdf
Adam
Academic Product Manager
National Intruments
(2,833 Views)
