I cannot recognize whether you are looking for a online or offline processing in Matlab®.
For online processing you have generally two options:
- High level implementation with TCP/IP or UDP communication between LabVIEW and Matlab®
- Low level implementation with the "Matlab® Node" (located in Functionspalette - Mathematics - Scripts & Formula - Script Nodes - Matlab® Node)
- The Matlab® node is the easiest way to establish an online communication. The variables of the Matlab® node (input and outputs) are directly accessible in the Matlab® workspace. This means you can read the variables declared as inputs and write variables which are declared as output.
For offline processing might use the easiest way: File Input/Output
Use the following link for further information on this topic: http://digital.ni.com/public.nsf/allkb/562D29142BF79B4E862570D10074E3CC?OpenDocument
More information on the Matlab® node can be found here:
http://digital.ni.com/public.nsf/allkb/93DDF49DA2EFED528625670B005B48E9?OpenDocument
ThSa
Message Edited by ThSa on 10-16-2007 12:39 PM
