This time I am writing regarding the PXI-6133 external timebase from PXI-6653. Until now we discussed about the PXI-4472 and it seems that it can be done similarly using the PXI_Star. I was wondering if you could give me some guidelines regarding this issue.
As far as I can see the board does not use oversampling so I just should specify the DDS clock as the sample rate.
And later only to specify the external clock source which should be PXI_Star.
Of course I use all the time the disciplined clock software in the background. Is there something more which is needed?
However I observed that PXI-6133 does not support the SyncPulse feature in DAQmx as it was in case of PXI-4472. Is there any way to walk around?
Thank you for help in advance.
Łukasz
