PXI
DAQmx, NI-Sync, EtherCAT drivers for Linux/Linux RT
Hello NI community,
I'm not sure to understand how things work between NI products and Linux RT.
I want to use DAQmx (PXIe-4322), NI-Sync (PXI-6683H) and EtherCat (PXIe-8245) modules.
Will I be able to use perfectly the drivers modules in C++ in any latest Linux RT version without using the NI Linux RT patch ?
Thank you in advance for your answers.
(1,556 Views)
Linux RT is an OS. You use NI drivers to control the NI hardware.
To my knowledge, NI-EtherCAT driver is only supported in LabVIEW. There is C programming support for NI-DAQmx and NI-Sync though.
https://tmesystems.net/
(1,530 Views)
