PXI
DAQ Solutions not available on NI8176
DAQ Solutions not available on LAbview 6.1,DAQ Solutions button not highlighted cant be selected on opening Window. Hardware listed below.
- Installed on Embedded Controller NI8176/W2K.
- in PXI-1011 Chasis, NI 4472 in PXI slot, using a 6052E DAQ Card, SCXI Modules - 1540, 1520, 1102
(3,426 Views)
HEllo;
Probably what is missing there for you is the installation of the support files for Labview 6.1.
To get that installed, run the NI-DAAQ installer (from Add/Remove programs) and select the support files for Labview.
Hope this helps.
Filipe A.
(3,426 Views)
