11-07-2006 09:23 PM
11-08-2006 10:48 PM
11-09-2006 12:07 AM
Thanks Brian,
Your link didn't work (some error regarding having to sign in even though I was logged in), but I think I know which forum you are referring to.
The link to the Dev Zone temperature reader is: http://zone.ni.com/devzone/cda/epd/p/id/4543 (Quite useful in prooving it can be done).
I will look into using 3rd party dlls.
Cheers,
Oz
11-09-2006 08:27 PM
11-09-2006 11:21 PM
Hi Brian,
I should have been more clear. Thanks for the links. The examples are good in prooving it can be done, but it has not been a problem solver for me. The VIs can't be included in a stand-alone application and examples don't provide any dlls for use in my application.
I have investigated a few 3rd party solutions. Motherboard monitor provides a dll, however it is no longer supported and does not support NI-PXI controllers. HMONITOR is also ok, but does not provide any means of retrieving the CPU info using my own app. So far, the best solution is the Everest by Lavalys. This application outputs CPU information through shared memory, registry and WMI. However, it requires Everest to be run on the background and I would prefer a solution through a dll.
Does NI plan on providing a dll for use in retrieving CPU temp from PXI controllers?
Is anyone aware of any 3rd party dlls that allow retrieving of CPU info for the PXI controllers (maybe I should post this as a new forum)?
Cheers,
Oz
11-10-2006 02:04 PM
11-12-2006 07:35 PM
Hi Brian,
I am not sure how I can access a dll without the header file (the header file is not included in the example). If I am able use this driver for my application, are there any application notes on it?
Cheers,
Ozan
11-15-2006 11:43 AM
11-16-2006 09:36 PM
Hi Brian,
Thanks for your ongoing help.
Yes, the VI included can be used as a sub VI and works well... until I try to create a stand-alone application of my project... at which time the application builder complains about the sub VIs for measuring temperature.
Cheers,
Oz
Ps: For intermediate solution I am currently reading CPU temperatures via Registry using Everest by Lavalys.
11-30-2006 12:49 PM
