PXI
Continuous Analog Acquisition problems
I have some problems with sound application. My program continuous acquires sound
signal and puts the samples to the output immediately in C language with Windows XP
operating system. I am using two PXI-4461 modules and the controller is 8109. The
sample rate is 8000 and the number of samples to read and write per iteration are 200.
And the problem is my program can't run for a while. After a few minutes, the program
fails and returns the exit error that the read buffer overflow or write buffer
underflow. In addition, the delay between the input and output should be within 100 ms.
Is there anything I can do to solve this problem?
(4,661 Views)
Please help me!
(4,626 Views)
Are you using LabVIEW for the code or C? Mainly overflow of data happens when you didn't properly handle arrays and queues. Can you explain the code you have done?
(4,622 Views)
I wrote it in C language, the coding is in the attachment.
I have tried a lot of methods to solve this problem, such as return function, for() loop,  and write and read in different threads, and I found for() loop had the best performance but still all of the methods I tried in my program can't run for long time, After a few minutes, the program fails and returns the exit error that the read buffer overflow or write buffer underflow.
Hope for your help.
(4,615 Views)
