PXI
Connector Details: 68-Pin Male SCSI Connector on NI TBX-68
Dear NI Community,
I am currently designing a custom PCB to interface with the NI PXI-2536 switch module, specifically its columns. This PCB is intended to host a 64-pin ZIF socket and a 68-pin male SCSI connector. I aim to replicate the type of 68-pin connector used on the NI TBX-68 terminal block for compatibility.
Could anyone provide the specific name, part number, or manufacturer details of the 68-pin male connector used by NI on the TBX-68 terminal block?
Best Regards,
Tamer
(157 Views)
TBX-68 is a 68-Pin Female SCSI to 68-Pin Female Screw Terminal, DIN Rail Terminal Block.
PXI-2536 has VHDCI connectors. Reference: Matrix Switch Modules: Switches Cable and Accessory Compatibility
See NI Switch Mating Connectors for Custom Solutions or Cables
(134 Views)
