10-23-2006 02:11 AM
10-23-2006 05:19 PM
10-24-2006 09:58 PM
Hi
great to hear from you
i have attached some slides to better explain the scenario, hope everything is clear if not let me know........
please give advice on connections
thks
10-25-2006 03:53 PM
10-29-2006 09:05 PM
10-31-2006 10:21 AM
11-01-2006 03:33 AM
11-01-2006 12:11 PM
07-22-2009 08:09 AM
Nice post here, thanks for the info.
I am also planning to use for my thermal controller:
- PXI 4110 for heater drive.
- PXI 4351 for RTD interface (4-wires meas.!!), using the block terminal TBX-68T.
As I can read from your posts, one issue is unclear to my eyes:
- Do I need to supply excitation for my 4-wires measurement using PXI 4110?
07-22-2009 08:58 AM
I just forgot to add this, in case my question is not clear enough:
I see that there are current excitation channels in 4351, but:
I interpret from your drawings that you are wiring the heater drivers from 4110 through the 4351 terminal block TBX-68T. I thought this terminal block was intended to be used only for the 4351 module, for thermal readings, not for power output.
That is why I am asking.
