PXI
Configuring PXI remote system with cDAQ
I'm having some trouble configuring a PXI-8184 that reads from a cDAQ-9188 chasis (using MAX).
I see the PXI-8184 on my Remote System and I see the cDAQ-9188 on My System->Devices and Interfases->Network devices. The thing is that I want to see the cDAQ-9188 on the Network devices of my Remote System, since the RT target will be running alone. I'm not able to add a Network Device->VISA TCP/IP Resource, using Auto-detect of LAN Instrument or Manual Entry of LAN Instruments.
All devices (cDAQ and PXI) are connected to the host computer via a Router, using Static IP Address on the same network.
I want to say that it's my first time using PXI and Real-Time Development Option, so maybe I'm looking at it the wrong way.
The cDAQ-9188 chassis has four NI-9236 acquiring several strain gages.
I would appreciate your help.
Regards.
Gustavo
(3,206 Views)
Good morning, Gustavo,
Here a few books with some procedures to configure. Any questions please contact us.
NI cDAQ-9181 Ethernet Chassis Quick Start
http://digital.ni.com/manuals.nsf/websearch/DB1A35016A84F1EE86257823007B7F0B
Network cDAQ-9188 Configuration Information
http://digital.ni.com/public.nsf/allkb/A5AE89EBB3F8726086257854005196C0
NI PXI-8184/8185 User Manual and Specifications
http://digital.ni.com/manuals.nsf/websearch/21EA14688A77126F86256EC200456571
Sincerely,
Mauro Vera
(3,180 Views)
Thank you Mauro. However I found out that cDAQ device is not compatible with the RT OS.
http://zone.ni.com/devzone/cda/tut/p/id/6913
http://zone.ni.com/devzone/cda/tut/p/id/10622
Regards.
(3,177 Views)
