07-16-2009 05:22 AM
I am trying to find the solution of connectiong PXIe chassis to PXI-1 chassis. As I see in the forums, NI PXI-PCI8332+NI PCIe-8372 can make the connection valid. I am wondering another setup :"PCIe-8362+PXI8360+PXIe-8360" will work or not? Setup as below:
Install one NI PCIe-8362(Two ports) in the PC, and then install one PXI-8360 in PXI-1 chassis and one PXIe-8360 in the NI PXIe chassis,after that connect both PXI-8360 and PXIe-8360 to the PCI3-8362 card in the PC. Is it ok?
Solved! Go to Solution.
07-20-2009 12:06 AM
Hi Ivan,
Do you mean you are trying to control a PXI and PXIe chassis from your PC?
From the MXI-Express user manual here, the PCIe-8360 is capable of connecting to multiple PXI chassis with PXI-8360 inside. From the MXI-Express for PXI Express User Manual here, the same PCIe-8360 is capable of connecting to multiple PXIe chassis with PXIe-8360 inside. There is no mention of connecting to PXI and PXIe chassis together, so let me verify this with R&D and I'll confirm the answer with you.
As an additional information, daisychaining a PXI chassis from a PXIe chassis is possible using additional PXI-8331 MXI-4 card with the PCIe-836x and PXIe-8360 card.
Can I Daisychain Chassis Using MXI Express?
Victor
NI ASEAN
07-20-2009 02:13 AM
Hi Xian,
Thanks for your information. The daisy chain you refered is truely one of the solution. What I tried to explain in my previous post is as below:
07-20-2009 08:28 PM
Hi Ivan,
I have checked and the PCIe-8362 can be connected in the manner that you have depicted in the diagram in your post, to both a PXI and PXIe chassis.
Victor
07-20-2009 09:07 PM
Hi Xian,
That's really great! Thank you very much!
