PXI
Compatibility of PXI-1052 and PXIe-8133
Hello. I need to connect a PXI-1052 chassis and an embedded controller PXIe-8133. Is there a solution to convert a PXIe module to CompactPCI or PXIe to PXI?
Thanks.
With the best regards,
Flávio A. N. Sampaio
(2,916 Views)
Accepted by topic author Skyfs
Hello Skyfs.
Unfortunately, it’s not possible to use a PXIe controller with a PXI chassi.
PXIe controllers can only be connected to PXIe chassis and PXI controllers can only be connected to PXI chassis.
Lígia T. Ferreira
Technical Support Engineer
National Instruments Brazil
(2,871 Views)
