PXI
Compatibilidad entre controladores PXI-8184 y PXI-8840
Buenas compañeros!
Soy nuevo en el foro y me estoy iniciando en NI. Tengo una pregunta para ver si me la podriais resolver. ¿Son compatibles los controladores PXI-8184 y PXI-8840?
Me quedo pendiente de respuesta. Un saludo. Y gracias de antemano.
(1,515 Views)
If you mean to ask, can you use PXI-8840 in a chassis that was using PXI-8184, sure it is compatible as both are 'PXI'
Santhosh
Soliton Technologies
(1,477 Views)
Thanks Santhosh for your time and respond. The PXI-8184 is a discontinued product. I mean if PXI-8184 and PXI-8840 are compatible in terms of functionality, "the controllers".
(1,471 Views)
Yes, both are PXI based embedded controllers. 8840 is a huge performance upgrade compared to 8184, I believe you will run windows.
Santhosh
(1,459 Views)
