PXI
Closing VI reference using .Net
So again the easiest thing to do would be to change the name of the VI so they are not the same.  If that solution doesn't work for you I may have another idea.  Since there doesn't appear to be a dipose or destroy method, you might need to close the LabVIEW Application reference instead.  Something similar to
oVI = oLabVIEWApp.GetVIReference(cfg.VIFilePath, "", false, 0);
oLabVIEWApp.Quit()
Once you have removed the LabVIEW Application from memory you can reopen the reference and try calling another VI path.  Let me know if you make any progress.
Andy F.
Message 11 of 12
(849 Views)
Thanks, that is what i was doing ...... closing the LabVIEW application itself.
Message 12 of 12
(834 Views)
