12-21-2005 05:48 AM
12-22-2005 01:00 PM
Hello!
I suspect this question might be better suited for either the CVI or LabVIEW board. I
think you are either using ActiveX from a .NET environment to automate
LabVIEW. If so, could you provide some additional information on what you
are trying to accomplish? I suspect that you are attempting to run a VI
using automation and close the VI afterwards, but would like to keep LabVIEW
open so subsequent calls to run the VI will take less time to load. If
this is the case, you should open a reference to the _Application class, once
this is open you can use the methods mentioned above (open VI reference,
etc...) and finally use the _Application method "Close" to close
LabVIEW. I'm not exactly sure why your close front panel method is not
working, but perhaps if you provide a snippet of the code in the LabVIEW board
myself or someone else in the LabVIEW community can take a look at it and see
what exactly is going on.
Hopefully this helps! Please let me know if you have any additional
questions.
12-23-2005 02:39 AM
12-27-2005 04:17 PM
12-27-2005 09:54 PM
12-27-2005 09:54 PM
12-29-2005 10:07 AM
01-12-2006 04:20 AM
01-13-2006 02:00 PM
01-15-2006 09:47 PM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
