10-28-2013 04:52 PM
I am using a PXIe-1062Q for a test project that will be inside of a protective case. The power button to the chassis will be covered by a plate on the protective case that will make it annoying and difficult to power on using the power button on the chassis. The chassis will be plugged into a trip-lite power strip that is mounted in the case. Is there any way that I can have the chassis power on when I turn on the power strip?
Solved! Go to Solution.
10-29-2013 09:35 AM
I have also read on Ni.com that you can use the RS232 jack in the back of the chassis to turn on and off the power? the article i read described that i had to source power to pin 5 to turn it on. My question here is; Does NI make a controller that sources this power or do you have to configure your own controller using a RS232 cable? Any help here on this issue would be greatly appriciated.
10-29-2013 10:44 AM
I found an alternate route. Under the BIOS of the controller I changed the AC power Loss settings to TURN on after the AC power is returned. This allows me to use the power strip in my configuration to control the AC power distributed to the controller. The following steps will describe how I completed this.
The controller can be shut down normally using the start menu and "shut down"
The chassis's power button is still capable of turning on the power to the controller, but now when I shut off the AC power strip, and then return the power, the chassis controller powers up.
11-01-2013 11:41 AM
It sounds like you could also do what you are trying to do with the "inhibit mode" switch on the back of the chassis. On "manual" it will turn the chassis on when AC power is applied. You would then use pin 5 to turn the chassis OFF.
Either way works.
- Robert
11-11-2013 07:21 AM
we tried to use the inhibit switch, but since we are developing this test system to be used in the field, we did not feel that it was a very clean way to ask a client to turn off their test equipment. Thank you for your response.
